what lower radiator hose for l31 swap?
Old Jun 11, 2015 | 11:54 AM
mizz0313's Avatar
Car: 92 Camaro RS Heritage Edition PoloG
Engine: L31 Vortec
Transmission: 4160e
Axle/Gears: 4th Gen Torsion Rear/ 3.42s
cant seem to find a radiator hose to fit this swap please anyone who has gone through this help me. haven't tried any flexible hoses yet but have tried hose from 92 5.7 no luck, hose from truck no luck. im running truck waterpump and stock radiator
Old Jun 11, 2015 | 02:19 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: what lower radiator hose for l31 swap?
I am using a stock thridgen waterpump and a stock rad hose.
Old Jun 11, 2015 | 02:27 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
I to am using stock 305 water pump and hose . good luck ........
Old Jun 11, 2015 | 02:53 PM
mizz0313's Avatar
Engine: L31 Vortec
Transmission: 4160e
Thanks guys I will try again
Old Jun 12, 2015 | 02:46 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
did you drill the bypass in the block?
Old Jun 13, 2015 | 10:04 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
No - the way that I have everything routed works without the bypass.
Currently I have a line from the lower intake to the heater core, then back to the rad (factory setup), except I do not have the restrictor valve in place. This allows the coolant to still go through the system at a slower pace and does not overheat the motor. Similar to the bypass, but larger scale. I have been running this setup for 6 years.
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
lakeffect2
Aug 23, 2015 08:44 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
