5 speed
5 speed
If i would have a car with a 305 with a 5 speed transmission, and i put a 350, probably a LT1 ,could it handle the power? I know the reason GM didn't put 350's in the 5 speeds was because they were worried about the power being too much for the tranny thanks
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I've replaced my 305 with a 300horse 350, and I don't plan on keeping the T5 for any longer than I have to. Already scattered it once, with the stock 170hp 305!Even the best T5's are only rated at about 295 ft/lbs.I won't waste my money getting it rebuilt again and I wouldn't recommend it for anyone that drives their car hard at all.I Plan on buying a Tremec TKO in the spring. (rated at 550 ft/lbs!)
-Rich-
-Rich-
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i swapped a t-5 into my auto car before i sold it. never had a problem with it.as long as you don't power shift it and you have a good clutch and short throw shifter it will survive behid a mild 350.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The reason they didn't offer then was for emissions, really..
In fact, no 350 second gens with standard transmissions were offered in CA.
Thirdgens had the limitation for all states.
-- Joe
-- Joe
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
-Rich- [/B]
-Rich- [/B]
Elephantismo
Feb 13, 2019 12:51 AM
