motor side mount bracket size difference??
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I read this on another message board " You will also need new rubber motor mounts (about $20 at local parts store) and the engine side brackets that these mounts bolt to. Make sure you get the engine side motor mount brackets from a Camaro as they are a little shallower and are needed to get the engine to sit low enough in the bay." Is This for Real ?????I don"t believe The" side mount brackets" I used for my 350 swap were off a camaro.
......I haven't noticed any problems..anything I should be looking for??? Thread
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
knight72
Aug 10, 2015 09:32 PM
