mini starter and flywheel teeth question
Old Jan 22, 2016 | 11:19 AM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
i have a 400 sbc with a 153 tooth flywheel externally balanced. i want to run a mini gear reduction stater on my car because the stock one is too big and runs too close to my headers and causes hot start issues. my 400 is drilled to run either a staggered or strait bolt starter. but all the mini starters have 11 tooth gears and my stock starter only has 9. will the 11 tooth mini starer still match up with my 153 tooth flywheel? meaning.... is the 11 tooth gear still spaced the same as my 9 tooth starter just with more teeth?
Old Jan 22, 2016 | 12:09 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: mini starter and flywheel teeth question
have you considered running the later model GM PMGR starter? price one for a 96ish Camaro.
Old Jan 22, 2016 | 12:26 PM
Piston454's Avatar
Car: 1990 RS Camaro
i dont know know anything about those starters. whats so special about them?
Old Jan 22, 2016 | 12:29 PM
naf's Avatar
naf
they're a standard unit available at most parts stores with a warranty
they're smaller and lighter than the original
they're likely less expensive than an aftermarket model of comparable quality
being a permanent magnet gear reduction starter, they're plenty strong
Old Jan 22, 2016 | 12:33 PM
Piston454's Avatar
Car: 1990 RS Camaro
i see. i think i have my mind set in getting a regular mini gear reduction starter, but thank you for the info.
Old Jan 22, 2016 | 12:36 PM
naf's Avatar
naf
no prob.
I've used a few, returned one for warranty claim with powermaster successfully.
Old Jul 9, 2016 | 12:50 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Is this just the factory style starter for those cars? Go to local parts store and ask for 96 Camaro starter?
Old Jul 9, 2016 | 03:42 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Correct.
To go back to OPs question
The mini starters being discussed in this thread are often setup for both teeth types (153 and 168). Though this thread is old, for posterity's sake, just check the datasheet on the mini starter you're buying to confirm what flywheel it works with.
I am using a $50 one from dbelectrical and it's working great so far. No major hot start issues, yet.
Old Jul 9, 2016 | 04:36 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
The mini starter I was running on my stock 305, works fine on my 383 as well; I had to use the other set of drilled bolt holes to mount it, but the teeth fit fine.
Old Jul 9, 2016 | 06:09 PM
naf's Avatar
naf
if you're in the market, price the 96 camaro starter through RA. I've gotten a few of them there, although I've yanked a few of the off junkers in the yards.
Roadgypsy
Feb 21, 2016 09:09 PM
ev305tpi
Jan 13, 2016 05:29 PM
19irocz85
Jan 6, 2016 12:19 AM
Galaxie500XL
Dec 30, 2015 09:59 AM
FinnZ28
Dec 24, 2015 04:31 PM
