th700r4
Old Feb 3, 2016 | 02:23 PM
Jesse mini's Avatar
th700r4
hi
I,m building an offroad car, we had an 2.8 mpfi engine in it and we are now swapping it to a v8 engine, can enybody tell me about the gearbox will it hold for v8 power aprox 300hp?
Old Feb 3, 2016 | 04:41 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: th700r4
The 2.8 and the v8 have different bolt patterns. You cannot use the original trans.
Old Feb 4, 2016 | 01:08 AM
Jesse mini's Avatar
Re: th700r4
Hi I know that, but is the transmission the same inside, and is th700r4 a good transmission for V8???
Does anybody have the measurement for the bolt pattern of 2,8mpfi? because we need to manyfactor a adapter between the trasmission and new engine.
Old Feb 4, 2016 | 02:41 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: th700r4
The 700r4 is a great trans for a V8. This was the trans GM used behind most of the V8s in the 80's... The V6 and V8 trans are NOT built the same on the inside. The V6 one is much weaker, has fewer clutches (frictions)...
Here is some info on the diff, that I saved off the net.
The 700R4 was introduced in 1982 and used through 1993. There are 2 different types.
Type 1
* Found behind 2.5L 4 cyl. & 2.8L V6 engines.
* Uses 3 frictions in Reverse Input , 4 frictions in Low/Reverse, 2 overrun frictions, 4 forward frictions and 5 frictions in 3-4.
* Comes with # 554 servo
* 4 cyl. uses .371'' TV boost valve / V6 uses .391''
* Produced in 2 WD and 4 WD style.
* Has a 10'' diameter converter.
Type 2
* Found behind V8 & Diesel engines.
* Uses 4 frictions in Reverse Input , 5 frictions in Low/Reverse, 2 overrun frictions, 5 forward frictions and 6 frictions in 3-4.
* Comes with # 553 servo, except HP uses # 093
* V8 uses .421'' TV boost valve / HD & Diesel .451'' / HP .471''
* Early uses 27 spline input shaft / Late has 30 spline
* Has 12'' diameter converter.
Old Feb 4, 2016 | 11:46 AM
Jesse mini's Avatar
Re: th700r4
hi! thanks for the info, has anyone tryed the small bellhouse th700 behind a v8 engine? because it would fit better on the our jeep engine
MParks
May 31, 2022 01:15 PM
brodysZ28
Nov 26, 2011 12:35 PM
tthompson
Dec 2, 2010 08:07 AM
vorgath
Jul 8, 2007 09:28 PM
cormyr
Apr 11, 2005 12:06 PM
