'95 350 to '92 305 swap
2 trucks involved
'92 sierra, 305 5.0l, 2wd
'95 z71, 350 5.7l, 4wd
Swapped the 305 into the 95 chevy, took out the 350...everything hooks up fine...only thing replaced was timing gears inside the time cover...made sure the marks aligned, then installed it in.
Only thing is I'm reading about these 2 engines' different timing positions...305 at 12:00 position & 350 at 1:30 position...I either get a backfire thru intake or no fire at all.
Car: 1988 Camaro
Re: '95 350 to '92 305 swap
Your ignition timing is off. Adjust the dist.
2 trucks involved
It continues
Camaroz2892
Jan 31, 2016 10:11 PM
