Harmonic Balancer Help
Old Feb 22, 2016 | 02:49 PM
usmechanix's Avatar
Car: '91 RS Camaro
Engine: Custom Small Journal 327
Transmission: T-5 5 Speed
Axle/Gears: GM 10 Bolt 3.08
Hey guys. Just a quick question. I'm building a Small Journal 327 with aluminum heads and so on. I'm going to try and use the factory brackets for all accessories and the like if possible. Now my question is I'm trying to figure out what size Harmonic Balancer to use. If I'm not mistaken the factory size is 6.5 inches diameter? What Balancer are you guys using and also what timing pointer? I was really hoping not to spend $200+ if I can help it. Thanks for all the Help I appreciate it.
Old Feb 27, 2016 | 12:59 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Harmonic Balancer Help
professional product power force 6.75". With just a pointer , not a timing tab as the damper has the timing marks on it. Price is under $75
I used the same one for the last 15 years on a 62 327 then on the current 350. Both engines are 7,000 rpm engines
Old Feb 27, 2016 | 06:05 AM
usmechanix's Avatar
Car: '91 RS Camaro
That's awesome thanks!
Old Mar 1, 2016 | 03:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is the crank tapped for a damper bolt?
Old Mar 1, 2016 | 04:00 PM
usmechanix's Avatar
Car: '91 RS Camaro
Yup sure is
Old Mar 1, 2016 | 04:18 PM
five7kid's Avatar
That's good. Not all of the early small journal engines were.
85Irocbuild
Mar 18, 2016 07:30 AM
Rob's z-28
Feb 21, 2016 01:32 PM
racereese
Feb 21, 2016 08:18 AM
Gtaified
Feb 18, 2016 12:28 PM
3rd gen money
Feb 17, 2016 02:21 PM
