Just ordered L31R
Old Mar 8, 2016 | 05:32 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Just ordered L31R
After having way to many issues with my 89 firebird and my 350 build I just ordered a L31R crate engine for just under $2k shipped. I know the cam isnt anything special but at this point I just need to get the car on the road asap since I'm moving in a few weeks and this whole swap just snowballed and has taken forever.
I just wanted to make sure my parts from my old 2 piece rms 350 will fit the new engine- I've got an Edelbrock 2116 performer intake and rebuilt quadrajet, new mechanical dizzy w/ vacuum advance, and new water pump. Will all the bolt holes be the same so I can reuse my pulleys along with alternator? I know I need a different flywheel since my old engine was a 2 piece rms but will the clutch be the same? Will the starter bolt pattern be different as well?
Another thing I'm trying to figure out is the warranty in this engine-summit racing said it would be a 24month(not sure on miles) warranty installed in my car but the Chevrolet dealer I ordered it from said it'd be a 12 month warranty for me. I'm assuming any issues would be taken care of by any certified GM dealer so wouldn't the warranty be the same no matter who you order it from?
Old Mar 8, 2016 | 08:31 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Just ordered L31R
Starter should be the same. If you are still are using stock exhaust manifolds one bolt will not work. You need a flywheel/flexplate for a one piece rear seal camaro. You need a melonized distributor gear unless your engine already has a roller cam in it. All accessories on the front will bolt up. No provisions for a mechanical fuel pump on the l31.
Old Mar 8, 2016 | 08:42 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I've got a pair of shorties and I just ordered a flywheel. Happen to have a link or part number for the dizzy? My old engine was a flat tappet cam.
Old Mar 8, 2016 | 09:36 PM
BOTTLEDZ28's Avatar
Transmission: A4
The Vortec engine uses a different timing chain cover. Look up the details on google pertaining to the covers and crank pulley. I could have swore it wasnt a 100% swap there.
Old Mar 8, 2016 | 09:41 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I know it has the poly/plastic cover but is it a must to swap it out? I've heard of guys jb welding the hole for the crank sensor.
Old Mar 8, 2016 | 09:56 PM
RamIt's Avatar
Car: 1984 z28
I plugged mine with a freeze type plug with sealant vs swapping it out for the GM 12562818 cover that has the hole blocked off. Another way is to use a standard small block cover with removing the reluctor wheel behind it but then you have to space out the damper the width of the reluctor wheel.
Old Mar 8, 2016 | 10:02 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
I suppose JB weld could work , or a threaded plug the correct size . I was overly **** on my swap . you can get a cover with out provisions for crank sensor . that's what I did , I removed sensor ring also . as I reflect back it was a waste of time . good luck ....
Old Mar 9, 2016 | 12:11 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Intake manifold will not fit either. You need a vortec specific manifold otherwise, everything else on top is the same.
Old Mar 9, 2016 | 03:42 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Intake is a 2116 Edelbrock which is the performer vortec for a spreadbore carb. For the distributor if I just order one for a '87 Camaro and up will it be a melonized gear since '87 and up is 1 rms?
Old Mar 9, 2016 | 08:03 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
The L31 likely comes with a damper, that is ~0.100" shorter due to the reluctor behind it. As stated, if you change dampers to a "standard" one, you will need to remove the reluctor.
There is little reason not to use the Vortec cover. EFIConnection has a plug for $10 (120-00029), but their website is not coming up at the moment. Here is a Google'd picture:
That Edelbrock 2116 intake IS correct for Vortec. You are set there.
FYI: Intake for Vortec head vs standard SBC... Bolt holts are at different angle, and Vortec ports are higher, and a standard intake will not cover the Vortec ports.
Distributor - the factory 87 Camaro distributor is computer controlled, and is not comparable to your "new mechanical dizzy w/ vacuum advance". You can swap the gear on your distributor and reuse it... $40, $66, $104, $104.
Flywheel... you got covered.
Old Mar 9, 2016 | 11:20 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Parts should be here next week. I know I'll have to pull the #1 spark plug and rotate the crank until #1 piston is at tdc so I can stab the distributor but do the valves need to be adjusted before I try to start this engine?
Old Mar 9, 2016 | 03:38 PM
RamIt's Avatar
Car: 1984 z28
Should be good to run out of the crate. First thing I did was to rip the stock cam out
Old Mar 9, 2016 | 05:18 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
What cam did you end up using?
Old Mar 9, 2016 | 06:02 PM
RamIt's Avatar
Car: 1984 z28
A LT4 hot cam in the Vega and a Lunati 10030 for the Camaro (Engine on engine stand at the moment)
Old Mar 10, 2016 | 06:53 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
does the L31r Come with a pilot bushing installed?
Old Mar 10, 2016 | 07:22 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Doug Herbert has a roller cam 215 220 duration and 465 lift that should work really well with the Vortec engine. It will be close on the lift but I ran a flat tappet cam with 465 lift on stock vortec heads and had no problems.
Old Mar 10, 2016 | 08:06 AM
RamIt's Avatar
Car: 1984 z28
No they do not. Almost all these engines were backed by an auto.
They are machined for the standard SBC bearing/bushing.
Old Mar 10, 2016 | 10:40 AM
UNCLE TOM's Avatar
no , but I think it's foolish not to installed new clutch kit while it's all apart . also get flywheel re-surfaced . good luck ...
Old Mar 10, 2016 | 01:20 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I've already got a new clutch and flywheel, guess I'll have to add a pilot bushing and the tool needed to remove and install one to the list.
Old Mar 13, 2016 | 03:11 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
engine will be here tomorrow so I'm trying to make sure I have everything needed-will I need an oil filter adapter and if so could someone give me a part number?
Old Mar 13, 2016 | 05:06 PM
UNCLE TOM's Avatar
no filter adapter needed . L-31 filter is a bit larger than a regular 305/350 . I am using K&N HP-3002 filter . good luck with swap ....
Old Mar 13, 2016 | 06:08 PM
RamIt's Avatar
Car: 1984 z28
Mine did not come with the oil filter adaptor/bypass valve. YMMV
http://www.summitracing.com/parts/aa...make/chevrolet
Old Mar 15, 2016 | 05:43 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
For the pilot bushing do I order one for a truck with a vortec 350 or are all sbc pilot bushings the same size?
Old Mar 15, 2016 | 07:09 PM
RamIt's Avatar
Car: 1984 z28
I may be wrong but I think all pilot bearings/bushings are the same for all small blocks. The clutch kit I bought for a 88 camaro fit perfectly including the pilot bushing.
Old Mar 15, 2016 | 08:15 PM
UNCLE TOM's Avatar
I agree , I know you want things to go good on your swap . don't go trying to chase down problems that do not exist . I say that as one who has chased many ghost's . been there , done that . good luck (again) ...
Old Mar 16, 2016 | 05:06 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Yea I figured it out-found a pilot bearing from my t5 and made sure it fit.
Old Mar 17, 2016 | 07:21 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
made some progress today!
Tomorrow I just have to prime the oil system, stab the dizzy in, fill the tranny with fluid,finish my Taurus fan wiring and put looms on all the wiring.
Umi relocation kit for torque arm
Old Mar 17, 2016 | 08:04 PM
RamIt's Avatar
Car: 1984 z28
Looks soooooo much better without the AC box in there. Very clean.
Do you have manual steering?
Old Mar 17, 2016 | 08:15 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Yep, s10 manual box with the Astro steering shaft. Still gotta get the correct fan for the delete box.
Old Mar 19, 2016 | 07:34 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
today I ended up changing the throttle cable to one for a carb-kind of a waste of time cause they were pretty much the same length. I should be getting the bracket fabbed up tomorrow.
Anyways I tried starting it and playing with the distributor-it'll start when I pour fuel in the carb then die a few secs later. Also there were flames coming out of my passenger side header-what exactly does that mean?
I disconnected the supply and return lines and tried cranking and didn't get any fuel which doesn't surprise me since I only heard the pump come on one time.
Is there a way to make sure the fuel pump is bad before I go through the trouble of dropping the tank and possibly rear?
Old Mar 20, 2016 | 08:43 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
1) an exhaust valve is adjusted too tight and hanging open.
2) Timing is way late.
3) You have plug wires crossed, making one of the cylinders fire 90-180* late.
Apply +12V to terminal "G" on the ALDL...
Or unplug FP relay, and apply +12V to the grey wire. To exclude the relay too.
Thanks to InfernalVortex...
https://www.thirdgen.org/forums/tech...ml#post5784724
https://www.thirdgen.org/forums/tech...ml#post5784839
Old Mar 20, 2016 | 05:27 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Just ordered an ac delco ep241 w/ strainer for $40. I've used walbro in the past but after hearing of recent complaints and the company's lack of warranty it didn't make sense to pay $100 and risk it.
Got the new pump in and nothing. No prime sound at all. I disconnected the lines from my 4309 while I cranked it a few times and no fuel.
Tomorrow I'm going to bring a friend so I can test the fuel pump connector.
I'm guessing I can't test the pump via the aldl connector since I've got a harness made by forum member Pocket? Also the new harness did away with the firewall mounted fuel pump relay.
Old Apr 2, 2016 | 02:11 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Bump
Old Apr 2, 2016 | 11:54 AM
RamIt's Avatar
Car: 1984 z28
Wish i could help but i have no factory electrical pump equipment on my 84.
Old May 30, 2016 | 06:31 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Much needed update! Over the past month I've been pretty busy-just moved from Colorado to Virginia and I'm transitioning out of active duty to a new civilian job as well as reserve unit. I made the move with the help of a friend and my two dogs since my wife is stationed in Korea right now and I'm finally getting settled in my new place.
Anyways the car is at a buddy's house an hour from where I live but today we finally got the wiring sorted out. Now I just have to clean the wiring up, replace the 4309(has a crack in the body), install my new mr.gasket throttle bracket and order a new lokar throttle cable.
I took a few videos today but I'm not sure how to post them on here.
Old May 30, 2016 | 06:51 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Old May 30, 2016 | 06:59 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Old May 30, 2016 | 07:04 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Just a simple swap nothing crazy.
Old May 30, 2016 | 07:08 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
V1nom
May 9, 2016 09:23 AM
mustacheman654
Mar 9, 2016 06:32 PM
1Aauto
Sponsored Vendors
Mar 3, 2016 11:28 AM
411moose
Feb 27, 2016 08:17 AM
