Crate Engine
Old May 11, 2016 | 12:20 AM
RedRoo's Avatar
Car: '82 Camaro Z28
Engine: 5,7l (GM Crate Engine(?))
Transmission: 3 Gear Automatik TH350
Axle/Gears: Borg Warner 9 Bolt, 2.77
Crate Engine
Hi, I need some information about my engine. I think it's a Crate engine from GM. The number that I have found is: V0909ZZ1. Thank you for any information.
Old May 11, 2016 | 12:29 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Crate Engine
I would say it's a ZZ1, but aren't they denoted ZZZ?
Old May 11, 2016 | 02:39 AM
RedRoo's Avatar
Car: '82 Camaro Z28
Re: Crate Engine
Thanks. It's my first V8 and I want to know everything about my car. What do you know about the ZZ1?
Old May 11, 2016 | 05:48 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Crate Engine
Its old.
Quick google search found some info here.
http://www.montecarloss.com/communit...&Number=882750
And here.
http://www.crateenginedepot.com/pdfs/SB_zzengine.pdf
Old May 11, 2016 | 09:45 AM
RedRoo's Avatar
Car: '82 Camaro Z28
Re: Crate Engine
Thank. This helps. Does anyone have any idea when these engines were built? I think about 1987 Due to the valve cover. These have in the center since 1987 four screws. Is that right?
Old May 11, 2016 | 04:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Crate Engine
There should be date marks cast into the heads & block.
Old May 11, 2016 | 06:21 PM
TTOP350's Avatar
Re: Crate Engine
If I recall, the first ones had a 2 piece rear seal and non roller block.
Old May 17, 2016 | 06:18 PM
five7kid's Avatar
Re: Crate Engine
Don't believe that's true.
Old May 17, 2016 | 06:36 PM
TTOP350's Avatar
Re: Crate Engine
I got my wires crossed, I was thinking of the generic goodwrench crate for some reason.
Thinking the ZZZs started around 89-90 (back when I was cool)
Old May 18, 2016 | 11:37 AM
five7kid's Avatar
Re: Crate Engine
That crossed my mind.
peterc005
Dec 28, 2017 02:20 AM
Venom Dimeslime
May 11, 2016 06:14 PM
db057
May 7, 2016 08:07 PM
someone972
Interior Parts Wanted
Apr 22, 2016 11:28 AM
KoriNoKage
Apr 18, 2016 01:01 PM
