Replacement radiator ideas?
Old Dec 26, 2001 | 12:33 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The radiator in my '82 Z28 needs to be replaced. But I am going to install a DFI 406 this summer. I want to install the factory type oil cooler that runs the oil through the radiator. Do I need/want the 3 tube radiator? And what do I ask for at the parts counter? i.e: 19?? Camaro W/??? and A/C, Auto trans. I think the 1LE cars had this set up. Do I need to get the radiator from GM? I had the part #s for the GM oil cooler kit (less radiator) somewhere but I lost them.
I know some of you guys have done this already. But my search could not find the old post.
Thanx,ANDYZ28
Old Dec 27, 2001 | 09:00 AM
MidnightZ's Avatar
I don't have the oil cooler, but I purchased a Griffin aluminum radioator from summit size 31x19. I love it and it works great. Not a direct fit, but easy to make it work.
Old Dec 27, 2001 | 03:42 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The oil cooler on the TPI cars cirulates coolant thru an adapter housing above the filter. (as opposed to running oil thru the radiator.)
Old Dec 27, 2001 | 05:55 PM
ANDYZ28's Avatar
Car: 1982 Z-28
So none of the 3rdgen cars had an engine oil cooler in the radiator?
Old Dec 28, 2001 | 08:09 AM
scauffiel's Avatar
Not in the radiator, no. You can buy one of the stacked plate oil coolers from Summit and place it in front of your radiator if you want one. The oil coolers that came on cars were typically just a long bent pipe that the oil was pushed through to cool it off a little, not real efficient.
Steve
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
Zachattack0925
Aug 12, 2015 09:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
