parts from one engine to another
Old Aug 6, 2016 | 10:30 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Transmission: TH700R4
Axle/Gears: 9 bolt
So, i have a 1985 305 with a bad block and heads, new intake and new carb, and a 1994 305 TBI engine.My question is this.....can i take the intake and carb off the 85 engine, and put on the 94 engine? Thanks in advance!
Old Aug 6, 2016 | 01:55 PM
Re: parts from one engine to another
Not quite; but you can easily buy an intake to fit the 94 motor for real cheeeeeeeep, and a 86-up flex plate, and then use everything else off the 85 motor on it.
Old Aug 7, 2016 | 09:23 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Yea, i know i can buy a new intake, but the intake on the 85 is only a couple months old. I was hoping to pop off the intake and car, and put it on the 94?
Old Aug 7, 2016 | 10:00 AM
That matters, because .... ??
Parts either fit or they don't. It could still be NIB and the advice wouldn't change.
It's possible to make it fit by elongating the holes and using angle washers but as cheeeeeeeeep as intakes are, better to just sell the one that doesn't fit and buy one that does.
Old Aug 11, 2016 | 01:11 AM
Night rider327's Avatar
Car: 1988 Camaro
Yep, Chevy used 3 intake bolt patterns on the sbc engines. 1955-85, 1986-95, then 1996-00 vortec
The 55-85 has 12 bolts with all bolts at a pretty steep angle.
86-95 has 12 bolts with the 4 center bolts at much less of an angle, just about straight down.
96-00 vortec has 8 bolts, no center bolts and all go straight down.
You can take an '55-85 intake and drill/slot the center bolt holes out, then use angle washers or a blob of RTV to seal up around the bolts and use it on 86-95 heads.
Mattkovitch
Jun 6, 2016 09:35 AM
Rpm92
Mar 30, 2016 09:32 PM
JL2000
Mar 16, 2016 05:26 PM
Brad
Aftermarket Product Review
Nov 3, 2000 03:34 PM
