Top or bottom
Old Sep 14, 2017 | 10:20 AM
KCG's Avatar
KCG
Car: 89 IROC
Top or bottom
I've done some 4th gen swaps out the bottom. Can the 3rd gen be done the same way? The threads I searched all went out the top seems like.
What have you done?
Old Sep 14, 2017 | 10:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Top or bottom
It can be done out the bottom, that's how they are built. I've always done them from the top on 3rd gens.
Old Sep 14, 2017 | 10:52 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: Top or bottom
I'm pulling the car apart for paint anyway, so I thought it might be easier to roll the engine harness in on the motor like a 4th gen. And just leave the engine whole to lower it.
Old Sep 15, 2017 | 08:02 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: Top or bottom
I should add this is a 305/T5 and both are coming out.
Old Sep 15, 2017 | 08:25 AM
shayapaula's Avatar
Car: 84 camaro z28 H.O
Engine: 305 H.O
Transmission: world class T5
Axle/Gears: 3.73 limited slip
Re: Top or bottom
I pulled my 305/t5 combo out of the top one of those load equlizers helped a lot I had the car on jack stands with a harbor freight 1 ton engine puller and I had to drop the car a bit for clearance.
Old Sep 19, 2017 | 05:50 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Top or bottom
pulled the original engine out of my trans am a couple months ago from the top, super super easy, would never even consider doing it from the bottom in these cars.
Old Sep 20, 2017 | 05:41 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: Top or bottom
Is that all you were doing tho....is pulling the engine out, nothing else?
Old Sep 20, 2017 | 06:03 AM
TylerSteez's Avatar
Engine: 383 stroker
Re: Top or bottom
no the 700r4 came with it, didn't need a leveler plate or anything.
Old Sep 25, 2017 | 04:38 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: Top or bottom
ok, well, I went against the grain and took it out the bottom.
Left all the front accessories, suspension, sway, steering, exhaust up to the cat attached. Removed the wheels and sat it on a dolly I had built before. Sat the trans on a jack and rolled it all out.
I thought the eng harness would unplug somewhere like on a 4th gen, but it doesn't. It continues on around to the front picking up everything under the hood.
