zz4
Old Jan 3, 2002 | 01:29 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
zz4
i have some q's about the zz4. First of all i once saw an add for a zz4 that came with all kinds of goodies for our cars like a new carb, airbox, ecm, etc. and cant remember where. DOes anyone know where i can get this, how much it is and where and for how much i could have it installed? Also what kind of times could i run with this in an 83 bird(700r4, 3.08 rears) w/headers, gutted cat, 40-series, and subframe connectors
Old Jan 5, 2002 | 10:01 AM
91-ZZ4-Z28's Avatar
I am a bit confused by you post you ask about a crate motor that comes with a carb. and an ecm. If you are talking about a TBI? than the kit you are talking about is the 10185077 - HO 350 Camaro Conversion any GMPP dealer sells them for about $4,415.47. If you are talking about a carb. application I don't know what you need an ecm for but the most complete motor GM sells is the 12496968 - 330/350 HO Deluxe for about $3,090.83 it is 330hp but is not a ZZ4.
Check out these sites for more info.
http://www.sdpc2000.com
https://www.spoperformanceparts.com
I hope this helps.
Old Jan 6, 2002 | 04:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The conversion kit you mention is for computer-controlled carb '82-'87 applications with automatic - that's why you need an ECM. It'll run in the high 13's/low 14's in an emissions-certified configuration. With headers and higher number gears, you should be a little deeper into the 13's. It's intended to be a do-it-yourself installation, but you might be able to get someone to do it for you for an additional $1500-2000.
The ZZ4 also comes in a Deluxe version that has the distributor & carb, but it is intended for '75-earlier or off-road applications only.
Old Jan 6, 2002 | 09:27 PM
MouseCamaro305's Avatar
l can comment on drivability and performance of the ZZ4 motor.
the ZZ4 is an amazing high-performance motor. the streetability and every-day drivability is phenomonal. my 87 camaro SC gets about 12-14 MPG on the street, and gets a few extra cruising on the highway, it stays at a constant 190 degrees even in the hottest most humid days, and comes up to temperature even on the coldest days. check my signature for track numbers and performance.
Old Jan 8, 2002 | 08:29 AM
91-ZZ4-Z28's Avatar
Sorry I should have looked closer at the conversion kit I thought it was for TBI.
Whare did you see the ZZ4 Deluxe I have never seen one form GM.
Old Jan 8, 2002 | 09:15 PM
five7kid's Avatar
Perhaps my meds have worn off. Either they used to offer it, or I'm confused.
It wouldn't be hard to make one. All you need are carb (probably cheaper from Summit than from GM), and other bolt-ons like flex plate.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
