Not sure what engine this is. Olds?
Old Jan 7, 2018 | 10:48 AM
nadrepadre's Avatar
Looking at an 88 firebird and this is in it. Its not an SBC and the owner has no idea what it is. I think it might be an oldsmobile but I'm not sure either.
Old Jan 7, 2018 | 11:07 AM
Re: Not sure what engine this is. Olds?
Yeah, looks kinda like it...
Also looks like a little too much "creativity" (wink wink, nudge nudge) was used in "installing" it.
Might make an OK parts car if the body & interior are in good shape, and if that motor isn't welded in or something, to where you can't get it back out.
Old Jan 7, 2018 | 11:09 AM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Yup, that's an Olds.
Based on the thermostat housing and valve covers.
nadrepadre's Avatar
Yeah I figured it probably wasn't worth the hassle. I really just need a straight roller hardtop 3rd gen that doesn't have fist sized rust holes in it.
Old Jan 7, 2018 | 01:43 PM
OrangeBird's Avatar
Car: 1989 Firebird
The upper radiator hose and the alternator bracket are a nice touch , I'll bet Sofa's right about it being welded in there ....
Old Jan 8, 2018 | 01:57 AM
GeneralDisorder's Avatar
I guess someone wanted it to be proper Buick/Olds/Pontiac complete with none of those filthy Chevy drivetrain parts.
Old Jan 13, 2018 | 07:58 AM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Chevy to olds isn't really a big deal if I remember correctly. I swapped one into a cutlass I had back in the day and I think all I had to do was change the mounting blocks on the crossmember. It was over 20 years ago tho...
Old Jan 13, 2018 | 10:18 AM
Drew's Avatar
After careful consideration.... It looks better than a lot of SBC swaps I've seen on Craigslist. I mean it doesn't even look like he cut a huge hole in the hood, and it doesn't have that stupid triangle Edlercrock aircleaner.
That has got to count for something.
Old Jan 13, 2018 | 12:15 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
I would actually try and get the numbers off the block and see what motor it really is. It may only be a 350 or (gasp) a 307, but on the off chance is a 403, those were a great motor.
barrentinec
Jun 15, 2011 12:25 PM
SillyWabbit
Feb 22, 2003 06:15 AM
The Dirty Bird!
Mar 1, 2002 04:29 AM
89 rock
Feb 23, 2002 10:20 AM
GoldenSwordZ28
Jan 8, 2002 09:56 PM
