Inrease my power please!!!!!!!
Old Jan 5, 2002 | 06:36 AM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Guys ,help me out here,
Ive got an 1985 5.0 tpi Transam and ive done just about everything to the 5.0 and i feel its time to step up the power a bit more.
What are your thoughts,should I,
1) strap on a supercharger
2) change the 5 for a 5.7 but use all the 5.0tpi bits
3)chuck it all away and buy a ZZ4 and TPI set up to siut it
I dont race it and a lot of my miles are done on a motorway(freeway to you lot).
Just i'd like a bit more acceleration when needed plus increased top cruising speed when travelling in europe with no speed limits.
it has to be totally reliable as well
What do you think??
powermite
Old Jan 7, 2002 | 01:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ZZ4 is a good but somewhat expensive change. You'll want to do TPI stuff that increases the upper RPM range and overall flow.
The '85 TPI wasn't all that good of a system. Converting to a later system would be a good idea. I don't think the '85 system would be too happy with either a 5.7 or a supercharger, but the power-adder and/or TPI guys may be able to help more along that line.
If you haven't done anything to the exhaust yet, that is a must. Assuming the system you got is similar to what we've got, that is.
Old Jan 7, 2002 | 01:55 PM
powermite's Avatar
Car: Transam
Thanks for your reply.I have gone as far as i want with the 5.0 so maybe ive got some thinking to do about whats best.
cheers
pm
Engine Mods
Dart Sportsman Heads
Comp Cams cam and roller rockers
Cloyes true roller timing chain
Headman headers
SLP Cold Air Induction kit
SLP T.P.I. throttle body airfoil
Accel Fuel pressure regulator
Hypertech Chip
SLP 3” Stainless Steel Exhaust system(no cat)
Old Jan 7, 2002 | 02:05 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Take everything you have on your 305 and bolt it on a 400
then port the sportsman heads.
Old Jan 10, 2002 | 09:31 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
Gears !!! I did not see what type of gears that you have, but if you have 2.73, swap to 3.42 for TPI or 3.73 for LT1/LT4. that was by best mod by far.
Old Jan 11, 2002 | 08:57 AM
powermite's Avatar
Car: Transam
Thanks sbrice but i already have 3.73 gears
pm
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
