MSD digital 6AL for 1987 Formula
Old Jun 9, 2018 | 01:05 PM
86Formula/Iroc's Avatar
Car: 1986 Firebird Formula all options
Engine: 305 tpi soon to be 383 stroker
Axle/Gears: 4/10
I was looking at the MSD 6AL digital ignition with the rev limiter box for my 1987 Formula with a carbureted 383 stroker with absolutely no electric anything it is running fully on it's own. How would I make this work and what all will I need to make this work and how do I hook this up. Thanks
Old Jun 9, 2018 | 05:43 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: MSD digital 6AL for 1987 Formula
look on their website it comes with instructions on how to wire it very simple
Old Jun 11, 2018 | 09:06 AM
Go Blue's Avatar
What made you go with the digital 6AL vs the standard 6AL? Did you do much research to see what the differences were? I'm wanting an MSD box as well, but I haven't bitten the bullet either way as i'm not sure what makes the digital box that much better??
Old Jun 23, 2018 | 12:16 PM
Axle/Gears: 4/10
Can I use my Accel Supercoil with the digital 6AL and maybe if I get a MSD distributor.
Old Jun 23, 2018 | 03:49 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
unless you are blessed with a 500-600+ horsepower smallblock , a properly setup hei is simpler,cleaner and easily works as good as it will ever need to to do its job.
msd boxes just add more electrical connections,complexity and another thing to go wrong.are you racing?do you need a rev limiter?is there a reason for your purchase because if you have a relatively stock car it will do nothing other than add weight.
if you have a turbo and need to pull timing,go for it.if you need a 2 step
and rev limiter ,go for it.if you drive around your neighborhood dont bother.
Old Jun 27, 2018 | 01:43 PM
Axle/Gears: 4/10
Yes I race the car. It has a 383 stroker that is built up pretty big. Will an HEI work with a fully carbureted car?
Old Jun 27, 2018 | 05:46 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
yes it will,absolutely.if you are using nitrous or need a boost controller because of a turbo/blower then you might want to look into an msd or equivalent but if you are running a relatively mild 383 with a carburetor then a good hei with a good module,cap,rotor,wires and hotter coil will support 400+ horsepower pretty easily.here is my setup running a performer rpm and a holley 650 dp.
performer rpm,holley 650 ultra double pumper
Old Jun 27, 2018 | 07:36 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
The digital 6al low rpm multi spark is nice and the soft touch rev control is good insurance if your racing. If you don't want to spend the coin msd has a street fire version also. There's a good chance your car already has hei
camaro1122
Jul 24, 2011 03:18 PM
Hole-Shot
Mar 3, 2010 07:06 AM
2laneblacktop
Feb 6, 2003 12:51 PM
Kevin91Z
Aftermarket Product Review
Nov 13, 2000 07:15 PM
