What oil pressure sensor???
1991 camaro with intellitronix dash need to find an oil pressure sensor that matches the correct psi range for a 454 and is the correct ohm range for the dash. I’m thinking a 0-80 psi sensor that converts to 0-90ohm but I’m not sure if that’s right. Car is wired with a painless harness and is a single wire sensor. Any info would helpful, thanks
firebirdjosh
06-30-2006 12:20 PM
330hp_91RS
03-11-2003 10:13 AM
Couldbeone
02-25-2002 11:08 AM
