Engine bay dimensions
Old Mar 4, 2019 | 12:50 AM
Smashdragon383's Avatar
Hello everyone I need to know the dimensions of a 3rd gen camaro engine bay for a prospective swap. I don't know the correct term for everything so I'll just be as descriptive as possible. It's gonna be an engine/trans combo so I'll need the following measurements:
Width from inner frame rail to inner frame rail
width from inner wheel well to inner wheel well
Width of oil-pan saddle (not entire k member)
length from firewall to radiator
length from firewall to rear kmember
Length from rear kmember to radiator
Height from k member to top of strut tower
Height from kmember to top of motor mount
Height from kmember to top of tranny tunnel
tranny tunnel width, length, and height
Tranny tunnel taper (width at front, width at rear, is taper more linear or very rounded)
I sold my camaro a while ago so I don't have it to measure with. If everything is go after the measurements then I'll pick up a roller. Once all the measurements are found they could be posted on the FAQ board for the future.
turbo2825psi
Apr 30, 2012 10:12 PM
Ca[maro]88
Feb 20, 2011 07:32 PM
rsrsrs
Sep 12, 2007 08:03 PM
Mr. IROC-Z
Mar 22, 2001 09:33 AM
