More L31 Questions.
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
More L31 Questions.
So just ordered a L31 crate motor From GM performance for my 92 with the ol TBI 305. Just finished rebuilding the 700r4 that was in it when I bought it. For exhaust I got some Hooker 2055s and a 3 inch catback from jegs. Also got a GM 12464340 dual plane intake to go with an Edelbrock AVS2 1906 carb. Have quite a few questions. I have been reading all I can but some threads don't go into details about little things. Sorry for my noob questions.
I know all my accessories will bolt right up. I have it understood that I need to transfer my timing cover and balancer from my 305 over to the L31. Some say I can use the L31s HB. Which do I use for a more simple setup?
As for the TBI wiring harness, what do I reconnect? Wondering about the starter, alternator and vss wiring.
Which fuel pressure regulator would work well with the TBI intank pump? Saw some mention a mallory and some aeromotive part nos. Seem pricey.
Will my stock throttle cable and bracket work? Seems long enough., I ordered an edelbrock 8032 bracket just incase.
The flexplate from my 305 will work just fine I have read. I have a complete L98 to pick parts from if needed. I'm gonna run the stock L31 cam until I feel I need more horses.
I have read I have to use a melonized dizzy gear for the roller cam in the L31. Can I use the dizzy gear off my 305 dizzy since it has a roller cam as well?
As I have it understood I have to run a hose from the water pump to one of the ports on the intake correct?
One more thing about the timing. As I have read, people say the timing marks will be off with the original sbc timing cover. In this case all I have to do is put the motor at TDC and mark were 0 TDC is at on the balancer in relation to the timing tab?
Sorry for the noob questions and your help is very much appreciated.
Engine: LB9 305
Transmission: AT
Re: More L31 Questions.
How the Hell are you gonna pass Cali SMOG, without the LB9 TPI 's INTEGRAL EGR and lack of visible ignition timing scale? I want a L31 for my '89 IROC Z, but wouldn't expect to pass SMOG.
Car: 92 Z28 Clone
Engine: Vortec 350
As for timing it, Ill get it timed. Eventually. Last edited by maroe624; May 5, 2019 at 11:43 PM.
Engine: LB9 305
Transmission: AT
Below is the best L31 tutorial, I have found.
https://www.thirdgen.org/forums/engi...31-r-swap.html
Car: 92 Z28 Clone
Engine: Vortec 350
wHAT ABOUT NEXT TIME, YOU NEED A smog? Inspector will be looking for the 305' TIMING INDICATOR and EGR? I hope it passes!
. But no seriously simply swap my LO3 back in with another rebuilt transmission I will have on standby. Thanks for the link I will read up. Joined: Jan 2005
Engine: LB9 305
Transmission: AT
Something I would have considered doing, when I was a young man! L31 IROC Z Vert is gonna be a blast to drive!
intex1982
Theoretical and Street Racing
Nov 21, 2019 09:01 PM
ambainb
LSX and LTX Parts
Jul 16, 2019 02:31 PM
btheri3
Dec 13, 2002 09:33 PM
