86 TPI 305 into 4th gen camaro no fuel pulse
Old May 15, 2019 | 06:05 PM
zftpi's Avatar
hello!
We are currently taking the engine from an 86 transam sadly it was too rotted out to even bother with but the engine did run. It runs when starter fluid is sprayed straight into the intake and runs well. We arent getting any injector pulse at all. We have the ignition control module harness not plugged into anything and basically what we are trying to figure out and cant seem to find any information on is where this plugs into. We also arent getting any check engine lights. We arent getting any power to the pink/black wire to the ecm either.
Old May 15, 2019 | 06:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 TPI 305 into 4th gen camaro no fuel pulse
Old May 15, 2019 | 06:51 PM
Engine: Lb9
Transmission: M20
A6 at the ecm has no power ?
Old May 15, 2019 | 06:56 PM
zftpi's Avatar
Sorry we do have switched power at A6
Old May 15, 2019 | 07:00 PM
Engine: Lb9
Transmission: M20
What pink/blk wire are you referring to ?
Old May 15, 2019 | 07:02 PM
zftpi's Avatar
pink/black is a6 the ignition power to the ecm. in the photo the ignition control module ends in a 12 point harness and we dont know what it plugs into because its not plugged in were not getting power to the icm.
zftpi's Avatar
can we wire the icm directly to the computer via hotwire
Old May 15, 2019 | 07:11 PM
Engine: Lb9
Transmission: M20
Hei coil in cap ?
The icm get power from the switches ignition to the coil
Old May 15, 2019 | 07:14 PM
Engine: Lb9
Transmission: M20
Old May 15, 2019 | 07:15 PM
zftpi's Avatar
it fires and runs on starter fluid. the module in the picture is not connected to anything and we cant find what it plugs into. also the colors dont match the schematic you sent. a is blue/white b is orange c is black d is blue/black e is green and those colors matchup to the 12 pin harness on the other side.
Old May 15, 2019 | 07:20 PM
zftpi's Avatar
Old May 15, 2019 | 07:31 PM
Engine: Lb9
Transmission: M20
Wire the esc as pictured in the schematic post 2
use the letters on the terminals not the wire colors.
The lack of esc will not kill injector pulse or spark.
Miya for knock retard distributor control.
Old May 17, 2019 | 01:35 PM
zftpi's Avatar
Identifix points towards the icm/esc being at fault for killing fuel pulse but I don't think we're getting power to the computer. Can't figure out where the computer gets it's ignition power from on the other end. We're not even getting the check engine light on the guage cluster.
90caddy
Aug 22, 2012 09:29 PM
Ronny
Jan 14, 2011 10:29 AM
89RS_82Z
Aug 31, 2008 04:28 PM
