Vette/ZZ4 heads
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
They work on any standard SBC; I'm using them on my '89 L98 right now. They are similar to '87+ SBC heads except the center two intake bolts are angled differently; slight grinding on your intake manifold will allow it to still be used; this is what I did.
They won't work on an LT1 or with a Vortec intake.
Transmission: 4L80E/4L80E
They also don't have the exhaust cross-over passages, so unless you use a Vette intake, you'll have to rig up plumbing of exhaust gases up to the EGR valve.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
