Looking for proper L98 iron head equivalent castings
Old Aug 14, 2019 | 10:35 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
My local machine shop had this in their book:
I highlighted what I understand are the stock L98 casting numbers. I have also read to be careful that some 350 heads are restrictive. I am hoping to locate castings that will work as well as the stock stuff, if there are any. The machinist said he found the short block, but only a set of "175" heads which do not appear to be listed.
Old Aug 14, 2019 | 11:54 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Looking for proper L98 iron head equivalent castings
083 heads should be around. I'd call some of the bigger engine re-builders and have them check their inventory. Places like Coast Motor Supply.
I was going to use these heads if I could not find 083s, as they are similar/maybe better than stock. Has internal EGR passages so smog friendly. https://www.ebay.com/itm/VORTEC-HYBR...T/171430638393
Old Aug 14, 2019 | 01:52 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
I have a set of 083’s, but I would imagine shipping from NC to CA would make it an unreasonable expense. Would it not be more cost effective to buy the complete L98 that Dyno Don offered to you and have it freshened up?
Old Aug 14, 2019 | 04:30 PM
Engine: 350 TPI L98
Transmission: WC T5
Holy cr4p. I forgot about that. I just PM'd him.
Old Aug 14, 2019 | 04:35 PM
thtanner's Avatar
Hey maybe I can buy the short block off of you after you yank the heads off. I'd love an OE L98 shortblock with OE cam to rebuild for later.
Old Aug 14, 2019 | 06:01 PM
Engine: 350 TPI L98
Transmission: WC T5
Ill keep you posted...
Gallileo60
Feb 15, 2007 10:14 PM
mdhoward@family
Nov 24, 2003 09:11 PM
Nasty_Bird_'90
Jul 31, 2002 04:11 PM
83TransAm
Jul 29, 2002 05:04 PM
red witch
May 13, 2001 12:13 PM
