Holly LS 20-185 mid mount accessory drive
Old Sep 9, 2019 | 05:45 AM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Anybody have this? Yes a boatload of money at $1700 but it looks like an awesome set up. LS3/6L80E going into a ‘91 Camaro and this will be one of the last things I will need.
looking for suggestions and what’s worked best for everyone. I have a tubular K member so should not have any clearance issues.
Thanks everybody
Roy
Old Sep 9, 2019 | 08:19 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Holly LS 20-185 mid mount accessory drive
I wanted to run the mid mount system but you basically have to buy the whole kit. The water pump is integral to the bracket design an mimics what GM is doing on the GenV motors. You can save money if you just buy the Holley brackets and source your own accessories, but you cannot do that with the mod mount. It is all inclusive, including the ATI balancer, but you can save some coin buying the stuff separately.
Old Dec 5, 2022 | 08:22 AM
TazZ28's Avatar
I wanted to run the mid mount system but you basically have to buy the whole kit. The water pump is integral to the bracket design a mimics what GM is doing on the GenV motors. You can save money if you just buy the Holley brackets and source your own accessories, but you cannot do that with the mod mount. It is all inclusive, including the ATI balancer, but you can save some coin buying the stuff separately.
but with this (mid mount) front drive assembly will the power steering pully clear the power steering box??
charliemccraney
Nov 24, 2013 06:36 PM
unseenT/A
Jul 26, 2012 02:32 PM
GT150
Dec 1, 2008 02:20 PM
Guyver03
Aug 9, 2004 01:39 PM
87kevroc
Sep 12, 2001 09:07 PM
