Body harness prep
Old Oct 13, 2019 | 07:52 PM
johnson92's Avatar
Car: 1989 Iroc z
Body harness prep
Hey guys somewhat new here I have a 89 iroc z that I am doing a 5.3 swap on and eventually throwing a procharger on it, anyways I'm wanting to find out what wires I needs to keep on the engine and of I can cut any of the wires out of the body? Thanks in advance
Old Oct 13, 2019 | 10:10 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Body harness prep
https://www.thirdgen.org/forums/ltx-...third-gen.html
Old Oct 14, 2019 | 08:50 PM
johnson92's Avatar
Car: 1989 Iroc z
Thanks! I appreciate it guess I missed this one..
Old Oct 19, 2019 | 09:10 AM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
The main thing to remember is when you are cutting wires from the C100, leave a few inches just in case.
Old Oct 19, 2019 | 05:02 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Screw that, just take them out of the cavity, no cutting needed. Remove the lock, push the lock tab and withdraw. Easy
Old Oct 19, 2019 | 05:30 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
Thats seems like a lot of work. When I did my swap, I initially planned on doing the swap harness connections under the dash since the swap harness placed them there. I found it a lot easier to run the wires back through the firewall and connect to the short wires in the engine compartment. If I would have removed the wires from the connector, it would have been a pain. I had cut them about 6" from the C100 and taped them to the remaining wires going to the headlights. All I had to do is untape and reconnect.
Old Oct 20, 2019 | 09:33 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
It literally takes seconds to remove them from the connector, then you have nice long wires if you need later.
mg8100
Aug 8, 2009 09:13 PM
CAMAROJOKESTER
Jan 9, 2007 07:16 PM
ctimm_rs
May 13, 2006 11:29 PM
