383 Stroker EFI HP projections
Subscribe
Nov 13, 2019 | 08:49 PM
Hi there. As I start to get ready to have this engine built I am trying to get a rough estimation of what the dialed-in HP be so that I can select the proper ECM to apply to the motor. Here's my set up...
Holley stealth ram w/ new fuel rails
AFR heads 76cc 195s
36 lb Bosch 3 fuel injectors
52 mm BBK throttle body
Underdrive pulleys
cold air intake
Scorpion 1.5 rocker rollers
COMP Cams Computer-Controlled Cam and Lifter Kits CL08-305-8
  • Lift: .510"/.510"
  • Advertised Duration: 276°/290°
  • Lobe Separation Angle: 114°
Axle ratio is 3.45
LT1 T-56 6 speed transmission
Properly built and all things considered what should I expect for HP at the crank?
Appreciate your help
Reply 0
Nov 14, 2019 | 07:27 AM
Re: 383 Stroker EFI HP projections
430-450 flywheel. 360-380’s whp as an estimate
Reply 1
Subscribe
