Hood Clearance and 454
Old Jan 14, 2002 | 04:00 PM
Matt Finch's Avatar
Car: 1982 Trans Am
Transmission: Turbo 350
Axle/Gears: 3.23:1
I am seriously concidering puting a big block in my Trans Am. Unfortunaly, I Have Just got a hood mural done and don't want to hack the hood! Please tell me there is a way to do this swap without hacking the hood.
Thanx!
Old Jan 14, 2002 | 11:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Low profile manifold and drop base air cleaner "should" fit under the hood. It would be real close. There just isn't much hood space in a third gen even with a small block.
Old Jan 15, 2002 | 12:28 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Hood clearance gets REALLY tight on the Firebird because the fender line drops down. It can be done with a low-profile manifold and short air cleaner. Basically, you're looking at a low performance big block and you might as well use a beefed small block instead and run faster.
Old Jan 17, 2002 | 01:18 PM
Matt Finch's Avatar
Car: 1982 Trans Am
Axle/Gears: 3.23:1
How do you figure it would be a low performance big block? Just because you use a low rise dual plane manifold, doesn't mean you can't build power into it.
Old Jan 17, 2002 | 06:09 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yes it does.
Old Jan 18, 2002 | 05:00 PM
9.0L Firebird's Avatar
Depends on how high engine is mounted
Mounting the engine 1.5" lower in the chassis, I was able to get a Weiand Team G (tall single plane manifold) with a Dominator under the stock hood (no air cleaner). With reasonably sized manifold (Performer RPM) it should fit with a drop base air cleaner. Don't use one of those foam mesh air cleaners they don't work without hood clearance.
www.geocities.com/nydragracing
Old Jan 18, 2002 | 05:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
How were you able to drop it down? Custom crossmember?
Old Jan 18, 2002 | 05:34 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You can get a crossmember made by PA Racing with up to 2" change in engine height. You can also move the engine fore and aft.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
mr z28
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
