1984 TransAm LG4 engine swap
Old Jul 22, 2020 | 06:46 AM
jomalley1234's Avatar
Car: Firebird
Hi Guys.
I'm based in the UK and have a very tired 1984 TransAm 305 LG4 (I believe this is the 150 BHP engine)
I have been quoted £3200 to rebuild the existing engine and I really don't think its worth spending that.
I need help and advice on a crate engine.
How straight forward is it, what would you guys recommend engine wise, i'm not after big power, with minimal work to swap over?
As my existing engine components are worn I can't see a possibility of reusing much including the carb.
Old Jul 22, 2020 | 07:36 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: 1984 TransAm LG4 engine swap
If you aren't worried about huge power then a Goodwrench 350 would be a cheap easy choice. It will still be atleast 50HP over your LG4 so yeah a noticeable difference for sure. If you want a lil more power then go for a Vortec crate engine it wont be too much more and carbed intakes for them are reasonable as you would have to have a Vortec specific intake. A mild cam and headers on a carbed Vortec engine will pretty much double the power of your old LG4.
Old Jul 22, 2020 | 08:40 AM
BigDogBob's Avatar
Car: 86 Trans Am
Engine: Carb'd LM7
Transmission: TH400
Axle/Gears: Stock 2.73
What dmccain said. Remember when picking out a new engine you'll need one that can run a mechanical fuel pump (unless you want to go about changing the fuel system).
Old Jul 28, 2020 | 05:04 AM
Car: Firebird
I was also considering the 5.7 TPI engine as I may have an opportunity to acquire one. any pros and cons?
Old Jul 28, 2020 | 07:09 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
If you can find one you can get a carb intake for it and it would be pretty straightforward. If you are wanting to go TPI then there are wiring harnesses from "PAINLESS" to fit your bill. Good luck.
Old Jul 28, 2020 | 05:43 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Wouldn't the existing LG4 parts swap over onto the 350 he may get? From what vehicle is this 350 coming from jomalley1234
Old Jul 29, 2020 | 07:22 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Pulleys and such. Intake will if its the same perimeter heads.
Jordan Ruddick
Jun 22, 2020 07:12 AM
BOLENBEVEL86
Jun 10, 2010 08:22 PM
aaf815
Theoretical and Street Racing
Nov 21, 2004 12:48 PM
Daishi
Jan 24, 2004 03:02 AM
Mich85TA
Aftermarket Product Review
Jun 5, 2002 10:58 AM
