Simple, maybe foolish question...
Old Jul 26, 2020 | 08:43 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Can I use my 1996 LT1 long block, to build an L98, for my 89 IROC Z 305/ Auto trans vehicle? Thinking Engine Quest heads also. Re use the TPI, distributor, add the usual 305/350 knock sensor, PROM, ESC, etc. Thanks.
If not, anyone want to buy and pick up my 1996 LT1 Core?
Old Jul 26, 2020 | 07:13 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Simple, maybe foolish question...
Accurately cut a hole for the distributor in the intake, set up a remote thermostat and sure you probably can use an LT1 with tpi components and ecm.
but being reverse cooling, different intake bolt holes and gear driven water pump will stop you from just interchanging parts between the 2.
Short answer, no, not without a complete LT1 that you'd have to meticulously modify.
Old Jul 26, 2020 | 08:07 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Thank you.
MODS might want to shut my thread down.
cml11109
Dec 18, 2007 04:00 PM
BaggedDropTop
Mar 12, 2005 12:45 PM
IROCaholic
Oct 25, 2003 10:00 PM
89 Iroc Z
Jun 7, 2002 04:04 PM
