85 305 TPI Swap to ZZ4 Swap
Old Sep 29, 2020 | 10:01 AM
Jjw2419's Avatar
I am swapping my 305 TPI for a Zz4 motor. I have been researching carb vs keeping my TPI system. Since my TPI is an 85 it sounds like it should just mount up, although it sounds like it is the primitive system. Would it be better just switching to a Holley carb, mounting my current system or going with a different fuel injection system. Emissions are not an issue in my state and I will be eliminating my cat and installing headers. I would really love to run a true dual exhaust but in reading that sounds like a nightmare and am better going with a aftermarket exhaust and run a 3” pipe. I want it to sound more beefy than stock but not much louder. Thanks for your input.
Old Oct 3, 2020 | 01:35 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 85 305 TPI Swap to ZZ4 Swap
The 85 tpi is the most primitive ecu for multiport injection. It can be converted to the 86 and later ecu. Can also move to EBL, Holley, Megasquirt or whoever and tune without changing the whole system completely. The factory tpi will severely diminish a zz4 compared to a carb or FIRST or HSR or just about anything.
IMO switching to any of those is just about the same amount of work to convert to a carb. I'd personally rather keep an efi car, efi.
How loud it is mostly depends on the muffler you're using. 420 hp can still be relativly quiet. Flow and noise, while related aren't mutually exclusive.
Old Oct 3, 2020 | 04:29 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
Google Mike Davis ZZ4. “My 85 Z28 and EPROM Project”
flomaster
Mar 9, 2020 08:22 AM
hi pinion
Aug 22, 2005 09:25 AM
My85TA
Aug 25, 2002 07:18 PM
trans87
Apr 2, 2002 01:15 PM
