305 TPI to ZZ4
Old Mar 28, 2002 | 09:04 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
305 TPI to ZZ4
How hard will it be to take out the 305 and swap in a ZZ4? Can I still use the TPI? I have A/C and wish to keep it is this possible? I am not doing this anytime soon but am looking to do this. I will do it once I get out of HS where I am going to enroll in UTI to become a mechanic. What is involved in doing this swap?
Old Apr 2, 2002 | 01:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hmmm, somehow you got ignored.
Check out this thread https://www.thirdgen.org/techbb2/sho...threadid=96015 . It's geared towards a certain performance objective, but most of the info applies.
The main problem you're going to have is that the TPI is a lower RPM system, while the ZZ4 is intended for higher RPM power. But, TPI improvements will get it there.
I assume you have emissions concerns. If so, the EGR will need to be fed via an external tube from the exhaust to the intake because the ZZ4 heads don't have exhaust crossover passages. But, the same situation existed on Vette TPI engines, so it's not uncharted territory.
Old Apr 2, 2002 | 01:15 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
five7kid is absolutely right about the stock TPI... it will just choke the power of the zz4... to make it run right a new intake, exhaust including headers, injectors, and torque coverter are musts... just to get started...
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
