LS Build
Old Sep 30, 2020 | 11:04 AM
rjcamel2355's Avatar
LS Build
Hey folks, I'm looking at building a 5.3 ls engine to go in my camaro. I'd like to at some point run a turbo on it also. Here is my plan so far, but I would love some input/build ideas. If I'm headed the wrong direction with my parts list, again I would love input.
I currently have a 5.3 .020 bored aluminum block so this would be my starting piece.
Below is my ideas so far.
243 heads
forged rods and pistons (open to brands)
pac1218 springs (or a btr kit with springs retainers etc)
ss2 .585 lift cam
Hardened push rods
Arp bolts/studs
80lb injectors
tbss intake (considering aftermarket sheet metal style)
ls7 lifters
Again, just trying to start a list of what I need to start gathering.
Old Oct 27, 2020 | 03:29 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: LS Build
I know most say use the iron block for boost but I think you will be ok. The bottom end is important to get right if you plan on boosting it.
Turbos and LS if you are going for a clean install (hood on exhaust out the back) is a tight fit so I would go ahead and relocate battery.
1992PonFirebird
Dec 5, 2012 04:35 PM
rspain85
Sep 12, 2010 01:05 AM
andrew91rs
Sep 11, 2007 12:53 PM
wreckspert350
Feb 20, 2005 05:45 AM
mhaskell
Dec 27, 2004 06:49 PM
