Dart engine assembly questions.
Old Dec 26, 2004 | 10:27 PM
mhaskell's Avatar
Is this engine any good, or just second rate parts? I am looking to top it with decent heads and a single BBs turbo kit. I am not looking to make 1,000hp or anything crazy, 600 or so is my goal but i want it to live forever. Anyone running this shortblock or dealt with this company before?
http://cgi.ebay.com/ebaymotors/ws/eB...943055763&rd=1
Dart Lil M
JE PRO SERIES Forged Race Pistons and MOLY rings
Eagle 4340 Crank INTERNAL BALANCE
Eagle 3d Hbeam Rods 4340 H BEAM
King RACE Bearings
Old Dec 26, 2004 | 10:40 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
It definitely isn't second rate parts, but if I were buying a new Dart block to house a 4" stroke crank, I'd opt to spend a few hundred extra bucks and get a tall deck block.
The std height block makes for a very tight squeeze with a 4" crank and 6" rods.
Old Dec 26, 2004 | 11:36 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Unless your looking for like 15:1 pro street stuff!!!
Old Dec 27, 2004 | 01:55 AM
Spdfrk1990's Avatar
Doesnt a tall deck throw the intake off? Does it take a special intake.
Old Dec 27, 2004 | 10:49 AM
Car: '85 IROC
Engine: LB9
A tall deck takes a special intake, or spacers.
They also require a special oil pan, because the pan rails are spread apart further to accomodate a large stroker crank. And a longer distributor too.
Old Dec 27, 2004 | 12:06 PM
mhaskell's Avatar
I can't see the benefit of a tall deck, it costs much more, and might not clear my stock hood. What are the benefits?
Old Dec 27, 2004 | 12:25 PM
Car: '85 IROC
Engine: LB9
A 4" stroke takes 6" rods min.
That leaves 1" for piston comp height, and that's a very tight ring package.
You specified that you're interested in longevity.
Try searching out a picture of a piston with a 1" compression ht. They look like a pancake with a wristpin through it.
A taller deck allows the use of a taller piston and longer rods, both.
Better for longevity.
Old Dec 27, 2004 | 06:49 PM
mhaskell's Avatar
Ahh makes perfect sense now, I assume the ring package might seal better when using FI also?
Cleotiz
Jan 6, 2018 08:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
