No fuel v6-v8 swap
Old Dec 9, 2020 | 12:42 PM
Jake Sinclair's Avatar
No fuel v6-v8 swap
Okay so I’m new to the page so if I’m making this in the wrong spot I am sorry.
I have a 89 rs that used to be v6 but now has a carb 350 small block. I am getting no fuel and would like some direction in what to look first. This is my first “muscle” car I am not familiar at all with them. The car will run with gas put down the carb but this is the only way I can start it. Any help would be greatly appreciated. Thanks.
Old Dec 9, 2020 | 07:13 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: No fuel v6-v8 swap
Sounds like the factory in tank pump either isn't wired correctly or just isn't working. I would start by making sure the relay for the pump is good and that it's getting power and is in working condition.
Old Dec 12, 2020 | 05:17 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've always removed the in-tank pump when swapping from any FI to carb; if your using a block mounted pump (or even an external electric) and the in-tank pump is still installed,...... you might not be able to "pull" fuel thru the in-tank pump properly.
Remember that Carbs only need about 6 pounds of fuel pressure and fuel injected pumps push too much PSI for a Carb. The fuel pressure needs to be regulated for the Carb to run properly.
Old Dec 17, 2020 | 03:41 PM
Thanks guys it turned out to be the fuel pump and I put a holly fuel pressure regulator on it.
tom h
May 21, 2009 06:41 PM
Fmaro
Carburetors
Oct 23, 2008 01:44 AM
Joshx3g
Jul 13, 2008 08:35 AM
96v6bird
Feb 8, 2008 12:54 AM
trendkill92
Carburetors
Aug 14, 2004 01:34 AM
