Swapping a 400 into a 305 TPI Trans Am
Old Dec 20, 2020 | 12:40 AM
9sinthe86TA's Avatar
Car: 1986 Pontiac Trans Am WS6
Engine: 383 Stroker
Transmission: TCI 725hp built 700R4
Axle/Gears: 94 Camaro 10 bolt. Posi 3.23
Hello, I am thinking of swapping a 400 into my stock 305 TPI Trans am. I was wondering the basics of what is needed to happen to do this conversion while keeping the stock gauges.
The 400 is going to have Dart 200cc heads with a 72cc combustion chamber, flat top pistons, a Weiand Xcelerator intake, and a 750 cfm Holley. I would use a non-cc HEI distributor.
1. Can I use the electric fuel pump with a fuel pressure regulator?
2. If I ditch the ECM, would my Tach and other gauges work?
3. How could I keep my cruise control? (I got to drive this sucker 3 hours to a race track)
4. Would the 700r4 need a torque converter lockup switch without a ECM?
I also plan to remove as little amount of wiring as possible incase I want to bring it back to stock to sell. Does the wiring harness just unplug?
Thanks, Sean
Old Dec 20, 2020 | 04:37 PM
NoEmissions84TA's Avatar
Re: Swapping a 400 into a 305 TPI Trans Am
https://www.thirdgen.org/carbswap/
Old Dec 20, 2020 | 04:59 PM
Engine: 383 Stroker
Ok thank you
bensbaby
Nov 6, 2016 06:35 PM
mbss_guy
Carburetors
Feb 23, 2009 06:56 PM
305Fan
Jul 7, 2004 01:30 PM
Nonni
Mar 12, 2002 09:48 AM
