350 swap
350 swap
Hello I tried to search for the info but couldn't find much I've been getting ready to put a carb 350 into my 1985 v6 camaro and was wonder about getting a fuel injection kit for it and was wondering if a v8 model harness and computer would be able to work and what else I might need to change besides my fuel pump
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 350 swap
the v6 fuelpump probably will be ok to use with a v8-depending on what injection/carb you plan on using. You should locate a wrecked/junk v8 3G to take all the needed v8 swap parts from
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 350 swap
Depends on what fuel injection setup you are wanting to run. A complete donor system will be the most plug n' play
88_Import_Slaye
Dec 31, 2005 08:41 PM
