serpentine accessory rig for 350
Old Mar 17, 2021 | 10:30 PM
photosbyty's Avatar
Car: 1989 Camaro 2.8 V6; 2011 Camaro RS
Engine: 2.8 Liter V6
Transmission: 5 speed manual
Greeting fellow Third Geners,
I have a 1989 Camaro RS that I have turned into a project car. I have removed the 2.8 V6 and am ready to install a 350 smallblock. (I know, I can hear the groans for not doing an LT1 but I wanted it old school) My issue is the accessories (ac compressor, alternator) stick up too far for the hood to close, the brackets are from a truck where hood clearance was not an issue. Is there any serpentine drives that will work on this application? I have found aftermarket gear for $1400 but I just have t believe that there is a more "pocket friendly" solution out there. I know the current configuration will not work because I have already installed on 350 into it and discovered that the "Newley refurbished" engine that I shelled out $750 for had a blown head gasket and it had been run so long that way before I got it that water had literally carved a canal between the 3 and 5 piston bore.
Any help, advice would be most appreciated.
Old Mar 17, 2021 | 10:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: serpentine accessory rig for 350
Why not use f body tbi and tbi serpentine setup ?
Old Mar 18, 2021 | 06:50 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
late 80's S10/S15
Boz2882
Jul 22, 2013 12:05 PM
Eric64
Mar 13, 2006 07:00 PM
geoman
Jan 7, 2006 01:36 PM
millerbn
Oct 6, 2004 01:16 PM
feelthedrama420
Sep 7, 2002 02:06 AM
