Serpentine setup
Old Dec 4, 2012 | 04:12 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
Transmission: BW super t10
Serpentine setup
The 305 im replacing had v belts. Im wanting to swap to serpentine but the brackets i have are from a van or truck. Whatever the 350 came from. Anybody have some decently priced aftermarket setups or would i be better off going to a junkyard and buying a setup there? I removed my air pump and ac compressor. Just need alternator and power steering.
Old Dec 4, 2012 | 05:26 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Serpentine setup
I believe the water pump is different rotation too.
Aftermarket is expensive due to show cars needing fancy billet looking pieces.
Once and awhile you can get lucky and get brackets 2nd hand and things for around $100-$200.
Overall I would think you're better off going to the junkyard and pulling them yourself. Remember alternator bolt holes changed depending on the year too, so if you pull the brackets off one car and grab the alternator on a second car make sure it bolts up.
Old Dec 4, 2012 | 10:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://sethirdgen.org/serpentine.htm
Old Dec 5, 2012 | 06:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Ebay, you can find some Fbody Serpentine set ups for around $100-$200, that's how I got mine, from a 1988 car.
Old Dec 5, 2012 | 06:38 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Serpentine is nice if you are running 5 accessories. If it's only WP, ALT and PS, I would just leave the V belts. Especially if you delected the A/C, because with the aluminum brackets, you will nedd to ADD an A/C delete bracket in order for the bracket that you just added to work. And those 2 brackets that you just added will run nothing but a tensioner.
Old Dec 5, 2012 | 07:12 AM
Twin_Turbo's Avatar
So what if it just runs an AC delete pulley and a tensioner? The benefits of the serpentine far outweigh staying with V belts:
Old Dec 6, 2012 | 05:07 AM
Boz2882's Avatar
Car: 82 Z28 Camaro
I had already bought a WP thats reverse rotation but i suppose it would be cheaper to replace the water pump again rather than all new(new to me atleast) serpentine brackets.
Old Jul 22, 2013 | 10:15 AM
N.J.-SLICK-1's Avatar
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
I am in need of the part number of the belt being used in this photo, that bypasses the pollution pump! Please help, thanks
Old Jul 22, 2013 | 10:25 AM
Twin_Turbo's Avatar
Stock belt, just routed different. Keep in mind, there's a better routing for more crank belt wrap but I like this way because it interferes less with the SC mounting studs/spacers.
Old Jul 22, 2013 | 12:05 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
It worked like a charm and Thanks for the quick response time!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
