No power from signal wire to FP relay.
Old May 20, 2021 | 01:03 PM
86swappedTA's Avatar
Help!
move to proper place too if needed. Need some help here. Have my swap complete for the most part. All electrical and such is done. I have no power from the signal wire to the Fuel Pump relay. Every other wire functions on the relay harness as it should. I have power to the harness. Just not the damn relay. Who can help?
this is the relay set up. The white wire doesn’t have power to signal the relay to come on.
Old Sep 8, 2021 | 09:15 PM
Felix87RS's Avatar
Car: 87 Camaro RS
Engine: 2.8 want to swap 5.7
Transmission: 700R
Re: No power from signal wire to FP relay.
Do you know if the signal is supposed to be coming from the ecm or is it from the ignition swich ?
Old Sep 8, 2021 | 10:20 PM
vorteciroc's Avatar
Top Answer: 1
I can not tell for certain from the Photo...
But it looks as if the Black Wires go into the Fuse-Holder portion of the Power-Distribution Center in the Image.
If the Black Wire is being triggered by 12V Positive from the Fuse-Holder...
Then the White Wire would need to be triggered by 12V Negative/ Ground.
Then Power from the Red Wires can make a connection via the Relays, to the Blue Wires.
Again... it is difficult to tell from ONLY a Photo... and NO Schematic.
mav75
Car Audio
Nov 11, 2013 12:04 AM
mav75
Nov 10, 2013 11:36 PM
ShaneBuss2
Jun 7, 2003 07:06 PM
JT 85 TA 305
Dec 8, 2001 06:15 AM
