Has anyone had success recently purchasing a remanufactured Chevy small block?
Old Aug 19, 2021 | 07:12 PM
jbradshaw77's Avatar
Hello!
My mechanic and I are looking to do a V8 swap into my '86 Firebird (currently 2.8L V6). We are running into shipping issues with our current prospective engine (they have no idea now when it may be available). I was wondering, before calling around and/or before considering rolling the dice on a motor from a junkyard, if anyone on here had recently had good success in obtaining a remanufactured engine from a company online? I'm in North Florida, if that helps. Thanks very much for any feedback!
J
Old Aug 19, 2021 | 08:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Has anyone had success recently purchasing a remanufactured Chevy small block?
Have you tried Summit or Jegs? The list of companies that sell SBC's is endless. Blueprint engines also should have inventory. What is your desired configuration? Your options are endless, but you can narrow your search if you know what you want. Don't discount craigslist or marketplace.
Old Oct 27, 2021 | 11:29 PM
7383camaro's Avatar
Car: 83 camaro 73 camaro
Engine: 305 454
Transmission: 700r4 powerglide
Axle/Gears: ? 370 ford 9
Since you are going from v-6 to v-8. Check out Summit, Jegs, Speedway and get a complete. Your going to need carb, manifold, dist, ect. I got a 383 coming from Blueprint. Should be shipped on 11-5. Like the above said, think its the best and easiest way to get it running.
Old Nov 1, 2021 | 10:19 PM
PonchoGTA's Avatar
Car: 1989 Pontiac GTA
Engine: 383 ci
Transmission: M29 T56
Axle/Gears: 9 bolt/3.27 gears 😫
I recently built a stout AFR-headed 383 from the roller cammed l98 block in my ‘89. But a great, easy combo would be to source a HT383 from GM performance parts. Not remanfactured. All new pieces and comes with a forged crankshaft, powdered metal rods (better than the old “pink” rods), and hypereutectic pistons. Actually marketed for trucks…but add a good dual plane, and a cam and spring swap to something like a GM hot cam kit which would work well with the vortec heads that comes with that engine. Be a fun, strong street car!
Old Nov 1, 2021 | 10:28 PM
ULTM8Z's Avatar
I just bought that short block. Hoping to get it assembled and fired up in the next couple of months. Ordered from Summit and it was drop shipped from Scoggin Dickey in Texas.
kevin j
Jul 28, 2012 10:58 PM
JJG04
Mar 19, 2009 05:31 AM
Mathius
Oct 18, 2006 02:11 PM
acidpad
Jul 20, 2002 11:42 PM
s0n
Feb 18, 2002 01:34 AM
