305 tpi in a car that had a 350
Old Oct 16, 2021 | 06:02 PM
Husky83's Avatar
Hi guys. I’m putting a 305 tpi in a 88 camaro that originally had a 350 tpi. I have all the front of the motor brackets from the 350 and all of the accessories-alternator ac smog power steering, but will the wiring harness be the same? Will there be any modification needed?
Old Oct 16, 2021 | 06:10 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 305 tpi in a car that had a 350
If everything is still there then yes, a tpi 305 can go where a tpi 350 was. Injectors should be changed to the 19lb 305 injectors and the ecm tune would need to be changed to a 305 tune. (Swap chips in the ecm)
there's a couple things that were 305 specific as I vaguely recall, knock sensor was different, icm maybe was different. Regardless the wiring is all the same.
PhAnToMs
Jun 8, 2021 09:58 AM
myiroc85
Jun 29, 2020 04:58 AM
86_WS6_Trans-Am
Jan 21, 2007 11:23 PM
