Skip white vs Ohio Crankshaft
Old Aug 7, 2022 | 07:35 AM
onebdgti's Avatar
I am gonna be in the market for a rotating assembly to build me a 383 stroker. Just looking for ideas cause this build is gonna happen this winter. Who would you go with a Skip White balanced rotating assembly or a Ohio Crankshaft balanced rotating assembly? I am looking a for about 600hp out of this build so a forged crank is a must.
Old Aug 7, 2022 | 08:17 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Skip white vs Ohio Crankshaft
I had Nyes Racing engines build my engine ad it has lived a very exciting and successful life these past three years. I am NOT easy on the car.
https://nyesracingengines.com/small-...y-short-block/
the will build short blocks AND you can buy parts from them if needed too
Old Aug 7, 2022 | 08:47 PM
vorteciroc's Avatar
Top Answer: 1
Skip's Business is an Automotive Machine-Shop of sometimes questionable Quality.
Ohio Crankshaft is a Business with Products that range from "Dirt Cheap" to stuff that will cost a Fortune.
Between the two, I personally would purchase from Ohio Crankshaft...
However, I do not believe that the differences will be much, if you are just shopping for a Budget "Off of the Shelf" Crankshaft.
Good luck, and have fun!
Old Aug 8, 2022 | 04:13 AM
onebdgti's Avatar
Not really looking for off the "shelf build". The motor already has a 400 turned cast crank with 5.7 rod and a set of hypereutectic piston.
This is why i asked. Looks like I am gonna be calling Ohio Crank a call.
Old Aug 8, 2022 | 05:59 PM
vorteciroc's Avatar
Top Answer: 1
That is absolutely the Modern equivalent of an "off of the Shelf" Build for a Gen-I SBC.
Old Aug 8, 2022 | 09:17 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
CNC motorsports is who I went with. Mine wasn't balanced because my machinist does it. Most machinist laugh at the "balance" these kits come in so be aware.
Old Aug 8, 2022 | 10:00 PM
vorteciroc's Avatar
Top Answer: 1
I second that!
Once you have all of your Components...
Pay to at the very least have all components (with a 50% Bob-weight Rule) Balanced within 0.50 Grams, if not 0.10 Grams...
and a Total Balance within 2.00 Grams or less.
Old Aug 9, 2022 | 06:32 PM
onebdgti's Avatar
I have looked into cnc motosports before. I just gotta call my local machine shop and see if he can balance a rotating assembly.
Old Aug 10, 2022 | 06:07 PM
vorteciroc's Avatar
Top Answer: 1
Ask about having it done "In House"...
Many Machine Shops will Sub-Contract for Balancing, NOT tell you, then double the Price!
Old Aug 11, 2022 | 05:52 AM
onebdgti's Avatar
Definitely gotta be in house. If the local shop is gonna ship it out then i will pay the price for a shop online to do it.
New2Chevy
Aug 1, 2009 12:21 PM
kylez28
Feb 22, 2005 07:01 PM
IROCBandit
Mar 12, 2003 05:41 PM
TheViper
Dec 6, 2002 08:35 PM
87TA 305TPI
Jun 11, 2002 04:51 PM
