Truck LS front accessories questions
Old Mar 23, 2023 | 04:24 PM
Ninedriver's Avatar
Ok. I have researched and read multiple threads regarding this topic but most are older or don’t answer what I’m looking for.
I am going to LS swap my 85 z28. I have an engine and I’m putting together a parts list.
The engine is a L9H , 6.2, from a 2011 Silverado. The engine is complete with all front accessories. I have purchased a LS3 intake to help with hood clearance issues.
Is there a way I can use/fit the engine with its original accessories (ps, alt, a/c, etc)? Also, is there a way to make it fit with the a/c and alt mounted lower?
Old Mar 24, 2023 | 11:00 PM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Re: Truck LS front accessories questions
I am using truck accessories and I cleared my hood just fine with “sliding” or “adjustable” engine mounts. When I swapped to a TBSS intake my clearance got pretty tight. Low mount AC will not fit without crossmember modification. I used a 1998-2002 LS1 camaro PS hose, screwed right in. Factory high mount truck alternator fit but I had to massage the hood very slightly and take a file to some of the ridges on the alternator.
Old Apr 9, 2023 | 11:01 PM
Dirty Elbows's Avatar
ICT Billet has an F body kit that places the ac compressor passenger side with power steering drivers side valve cover and the alternator below that.
Uses truck accessories, their swap guides are fantastic and they answer emails quickly. Just ordered the last of the goodies we need for our swap.
6..0 LY6 with a 4L80e....88 IROC
Old Apr 28, 2023 | 11:24 AM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
What you do with your rear end
Old Apr 28, 2023 | 08:27 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Put a posi in it because it had no traction otherwise lol
Anton28
Nov 10, 2020 02:36 PM
Ja85z28
Mar 18, 2018 07:06 PM
glocksrule
Mar 20, 2014 08:20 PM
Project 3.4 Camaro
Nov 14, 2011 07:32 AM
camaro_V6_Tuner
Dec 23, 2010 04:51 PM
