87 T/A LT5 swap
Old Mar 25, 2023 | 01:25 PM
Clean87TA's Avatar
87 T/A LT5 swap
First off I wanna give a big thanks to BajaDaze. He helped me out a lot on this project as I had many questions about this project and he helped me out. Go and check out his sick 89 IROC with this swap. A few years ago I started a thread about this swap I bought the engine parted out the electronics and stuff I didn’t need. I left it in a engine cradle as eye candy for the garage. I slowly started gathering parts like the K-member I had a MS3x I was planning on using. I was doing research but not much was out there so I put it on the back burner. Fast forward to now and it’s finally a runner been driving it locally so far so good. This car had a perfectly running Ls1 swap cammed 243 heads LT’s t56 and 4.10 gears. I pulled that perfectly running engine and rolled the dice on this LT5 not even knowing if it was a good engine. I started this swap on November of 2022 so it’s been down a few months.. it’s not perfect but we are getting there. anyways here are some pics
Old Mar 25, 2023 | 05:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 87 T/A LT5 swap
Looks incredible. How is the power difference?
Old Mar 25, 2023 | 05:07 PM
Clean87TA's Avatar
Re: 87 T/A LT5 swap
I really can’t tell a difference but then again I haven’t done a full 7k rpm pull with this one.
Old Mar 25, 2023 | 05:15 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: 87 T/A LT5 swap
Where did you find this motor? This is one of the few swaps where removing a cammed LS1 is acceptable.
Old Mar 25, 2023 | 05:21 PM
Clean87TA's Avatar
Re: 87 T/A LT5 swap
haha I’m sure these engines are reliable as long my wiring is all good i shouldn’t have any problems. I bought this engine a while back.
Old Mar 25, 2023 | 06:05 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Re: 87 T/A LT5 swap
Fantastic job!!
Old Mar 25, 2023 | 06:22 PM
Clean87TA's Avatar
Re: 87 T/A LT5 swap
Originally Posted by Buddy
Fantastic job!!
thanks brotha
Old Mar 25, 2023 | 06:24 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: 87 T/A LT5 swap
Tell us more about the swap. Exhaust? Mounts? Etc.
Old Mar 25, 2023 | 07:00 PM
Clean87TA's Avatar
Re: 87 T/A LT5 swap
Oh yea that’s right so for this I used an AJE Kmember with their mounts. I had to mod the mounts a bit because this one uses for mounting holes the AJE one didn’t lined up also I had to Notch the oil pan to clear the Kmember. For the headers I had bought some OBX headers for the Zr1.. I’ll tell y’all these where easier to install than the hawk budget headers I had on the swap. The driver side collector did need some work but it wasn’t to bad. I’m also running Texas speed true dual exhaust 3” over the axle. They do hand a lil by the diff but can move them up a bit.
This is how much I notched the oil pan.. I know some said I was nuts to do that .
Old Mar 25, 2023 | 07:10 PM
Clean87TA's Avatar
Re: 87 T/A LT5 swap
Mocking up the T56 which I had to convert to an LT1 style. I did have to notch the bell housing on the passenger side for the header collector to clear
LT5 next to the Ls1
My Ls1 setup before the swap
Old Mar 25, 2023 | 08:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 87 T/A LT5 swap
Both set ups were/are clean, but cant beat that LT5 look under the hood, great job.
gt4373
Jan 17, 2023 12:48 PM
gt4373
Aug 24, 2021 08:00 PM
89mulletbird
Jan 1, 2019 06:37 PM
gt4373
Mar 21, 2018 11:10 PM
chevyv8guy
Jul 16, 2010 08:53 PM
