85 z28 350small block swap
Old Nov 13, 2023 | 05:26 PM
ColT45ky's Avatar
I swapped in a 350 with a mechanical fuel pump I want to stay mechanical what all do I need to do with the tank sending unit what to do with old fuel pump I’m reading that you run a hose with strainer to run the mechanical? I’m lost any advice would help I appreciate it guys I really do
Old Nov 13, 2023 | 08:01 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 85 z28 350small block swap
you can remove the E-pump and replace with a length of gas-proof hose and a suitable strainer -just make sure it can pick up the lowest gas in the tank Presuming this was originally TPI,but certain carb cars '84-85 and all carb 86-87 had a low pressure helper pump in the tank-if it is that pump,you can leave it un powered and draw fuel through it since it is a turbine pump without a check valve.
Old Nov 14, 2023 | 02:05 PM
ColT45ky's Avatar
How can I tell the difference between the turbine pump and the regular pump with check valve?
Old Nov 14, 2023 | 02:06 PM
ColT45ky's Avatar
. What is the difference.between the pumps how can I determine what I got and sorry I got the year wrong I checked title and it’s an 84
Old Nov 14, 2023 | 03:03 PM
Do you even know that it has an electric pump? Most of the carb cars didn't.
Old Nov 14, 2023 | 03:07 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I think with the 84 you'd be safe just pulling through the stock in tank pump, if there's one back there.
calgutie
May 1, 2012 10:41 PM
my_lil_fire
Mar 22, 2011 07:47 PM
88KARRV6
Sep 30, 2006 11:21 PM
86z28stroker
May 18, 2004 07:22 PM
