Looking to add some more horse power
Old Feb 3, 2024 | 10:59 PM
Dlow1966's Avatar
Hello im looking for some advice on adding more horse power to a new crate Chev 350/357 hsp. Where and what's your thoughts..
As the latest in Chevrolet Performance’s Street Performance crate-engine lineup, the SP350/357 is designed as an affordable performer to match just about any budget. Better still, it uses strong components and modern technology to make it a better alternative to rebuilding. The SP350/357 leverages the strength of a strong rotating assembly secured in a brand-new block with four-bolt mains, and matches it with modern valvetrain technology to support high-rpm capability.
  • Horsepower
    357 HP
  • Torque
    407 LB-FT
  • Tech Specs
    Engine Type: Chevy Small-Block V-8
    Displacement (cu. in.): 350
    Bore x Stroke (in.): 4.000 x 3.480
    Block (P/N 10105123): Cast iron with 4-bolt main caps
    Crankshaft (P/N 10243070): Nodular Iron
    Connecting Rods (P/N 10108688): Powdered metal
    Pistons (P/N 88894280): Cast aluminum
    Camshaft Type (P/N 12677151): Hydraulic roller
    Camshaft Lift (in.): 0.473” intake / 0.473” exhaust
    Camshaft Duration (@.050 in.): 215° intake / 223° exhaust
    Cylinder Heads: Cast iron; as cast with 64-cc chambers
    Valve Size (in): 1.940 intake / 1.500 exhaust
    Compression Ratio: 9.0:1 nominal
    Required Fuel: Premium
    Maximum Recommended rpm: 5600
[img]/forums/images/buttons/user_online.gif[/img] Report Post
Old Feb 3, 2024 | 11:14 PM
bloodhound1's Avatar
Re: Looking to add some more horse power
I have the same engine, I have a First Performance intake on it, Holley HP ecu running it, headers of course. Haven't dynoed it but I will in the spring. None of that added any power I'm sure, but it's a great all around engine.
Old Feb 6, 2024 | 05:58 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
How much money do you want to throw at it?
You could put in a different cam and up the hp a little. If you want a big difference add these heads & a cam.
https://promaxxperformance.com/product/maxx-183-sbc/
They have other choices.
https://promaxxperformance.com/maxx-series/
Old Feb 10, 2024 | 09:38 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
What ^he^ said.
  • Horsepower
    357 HP
  • Torque
    407 LB-FT
Know that this is Gross HP. As installed, results will vary greatly depending on equipment, but it'll likely be under 300hp as installed, using hp metrics that we're more used to using. (how the OEM does it)....and you'd probably see something around 260 RWHP....ish. Better than stock for sure but not the same as an OEM car with "357 hp".
Dlow1966
Sep 23, 2024 07:48 PM
KingHD
Jun 23, 2017 02:02 PM
Outlaw28
Jul 12, 2012 07:53 PM
bad@ss89camaro
Aug 23, 2002 11:17 PM
