Repurpose return line
Old Aug 7, 2024 | 06:34 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Slowly collecting parts for my ls swap, and was curious if anyone had converted to a returnless system, and used the old return line to hook to the evap canister on the 4th gen tank to make everything functional? My plan would be to use the c5 filter at the back, have the original feed line still be the feed, but then just use the old return line as the middleman between the evap solenoid and the canister on the tank. Any reason this wouldn't work?
Old Aug 7, 2024 | 07:45 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Repurpose return line
If it is the right size and without leaks, go for it.
Old Aug 9, 2024 | 10:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Doesnt a return-less set-up still have a return line. It just Tees off at the filter and goes back to the tank.
Old Aug 9, 2024 | 11:00 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Right, but I can do all of that plumbing at the rear. So feed --> C5 Filter --> Feed & return to the tank, then reuse the return from the engine bay as the evap line.
Old Aug 10, 2024 | 04:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
LiquidBlue
Dec 18, 2021 06:54 AM
Danspeed1
Mar 30, 2011 09:19 PM
Ricco
Jan 29, 2011 07:08 AM
82flamedZ
Carburetors
Jan 17, 2006 02:00 PM
shaggy56
Jul 19, 2004 01:15 PM
