Interchangeable parts between 305 and 350
Old Oct 12, 2024 | 10:35 PM
drsnac's Avatar
Car: 1987 Trans Am
Planning on building a 350 and putting it in place of the 305 in my trans am. Im just wondering if all I need to buy is the block, and if everything else from the 305 will work with it. I dont care about things like the cam because Im planning on getting performance stuff for the engine.
Also its TPI
Old Oct 13, 2024 | 11:10 AM
Re: Interchangeable parts between 305 and 350
Block & pistons are the main difference. They have different heads as well but a 350 short block can be built to work well enough with 305 heads that the TPI will remain the primary limit to performance.
Everything else - tin, crank damper, flywheel or flex plate (as long as both motors are either 85-back or 86-up), distributor, and the entire TPI itself, are the same. You'll need injectors, the PROM for the ECM, and the right knock sensor; but the whole rest of it is the same.
racerx520
Aug 24, 2007 09:06 PM
hogan2468
Mar 29, 2005 06:24 PM
Ryknow86
Aug 29, 2003 11:08 PM
Pontiac4ever
Feb 24, 2002 09:57 PM
mike2468
Feb 17, 2002 10:42 PM
