Swap 2.8 V6 5-speed to 327
Old Apr 4, 2025 | 06:57 AM
BSkaggs RN's Avatar
Hello, I am new to the forum and a novice in mechanics. I have a 1986 Berlinetta with the stock 2.8 V6 and a T5, 5 speed. I am wanting to put a rebuilt 327 that came out of a 1969 Impala into it, but keep the T5 for now. I will eventually upgrade the transmission to a TKX or something, but for now I just want to put the V8 in and be able to cruise in the Camaro. What do I need to make the swap? Clutch? Input Drive? Flywheel? Bell Housing? I want to do as little as possible so I'm not investing too much in a transmission that'll eventually be changed. Thanks!
Old Apr 4, 2025 | 09:10 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Swap 2.8 V6 5-speed to 327
Bellhousing, FW, clutch, pilot bushing, might need a fork; not sure if they're the same or not.....for the engine to trans interface.
Old Apr 4, 2025 | 09:53 AM
BSkaggs RN's Avatar
From what I had found going through the forum, I figured as much. I was hoping someone has already done it and had recommendatuons on specific parts, kits, or anything.
Old Apr 4, 2025 | 11:33 AM
Engine: LT1, L400
Someone may. Last time I did a V8>T5 swap, I pieced every part together individually, using classifieds (paper) and Zeller Automotive (remember that place?).
Old Apr 4, 2025 | 11:57 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Everything; nothing from a V6 will fit a V8.
It's Deja Vu all over again in this forum.........
Old Apr 4, 2025 | 12:19 PM
Engine: LT1, L400
Say what? How will the trans itself not fit?
Old Apr 4, 2025 | 12:24 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
He said he was "Keeping the T5;" I assumed he already knew it would work.
....prob shouldn't "assume" anything here though..........
Old Apr 4, 2025 | 12:36 PM
BSkaggs RN's Avatar
I apologize, I want to clarify. I know that I'll have to change things for them to work together. I am hoping for some guidance on what though. What clutch have people used? Is is better to get a clutch for the 14 spline or change it to the 26 spline shaft? What has been done that works well but keeps me from dropping the k's on a new transmission in the short term and be able to enjoy the car this summer
Old Apr 4, 2025 | 12:46 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Your clutch question and any other questions that might come up when you get into this are answered here: V6 to V8 Swap - READ BEFORE POSTING NEW! - Third Generation F-Body Message Boards
Good luck!
Old Apr 4, 2025 | 02:23 PM
BSkaggs RN's Avatar
Good luck!
Thanks! I did read that prior to joining the forum. I thought I'd get lucky and with my specific application find a user that's already done it and could give a more detailed path to follow. I appreciate your responses
Mad Hatter
Apr 25, 2015 11:55 AM
Georgiaboy6985
Sep 21, 2011 10:20 PM
1989RSV6
Jul 1, 2009 03:10 AM
camaro350man
Jul 10, 2005 09:04 PM
caba004 camaro
Oct 3, 2001 02:29 AM
