Swapping 305 TBI with a 350 carb, 92 camaro rs
Currently trying to plan for my 350 swap, only main problem im having is related to the transmissions VSS sensor (700R4), will everything work fine if I dont remove the ecm and will my speedometerwork considering its electric? I've seen stuff about using a manual lock up switch but don't exactly know.
Re: Swapping 305 TBI with a 350 carb, 92 camaro rs
Why not just get a truck TB, chip, and knock sensor; a Performer RPM and a 4-bbl - TBI adapter; and just bolt it back together without touching any wiring? That way your transmission and speedo will still work, and you won't have to do all the wiring and whatnot to make the transmission work right with no ECM. IOW push the EEEEeeeeeeeeeeezzzzzzzzzzzzzy button.
