LT1 Computer ?
Old Feb 3, 2002 | 09:25 PM
troutkilla's Avatar
LT1 Computer ?
Hey Fellaz, I have a chance to pick up an LT1 motor with low miles for a good price.The problem is that I already done the T56 swap on my L98 T/A and the new motor comes with a computer for an automatic tranny.Are they the same or do I have to find a new computer for a manual tranny car?.......Thanks
Old Feb 3, 2002 | 10:20 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
That computer will work. you might have to have it programed to work properly though. I hear the pcmforless.com is the cheapest they will do a complete program for 99 dollars.
Hope this helps.
Kory
Old Feb 3, 2002 | 11:07 PM
troutkilla's Avatar
Thanks Kory.....Thats just the info that I was looking for.....
Old Feb 4, 2002 | 11:11 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Get LT1 Edit and you can do it all yourself, even disabling VATS and changing gear ratios for speedo corrections all yourself! Go to CZ28.com and read up about it, MUCH cheaper than sending out a PCM. Basically it turns your PCM into DFI kinda.
Old Feb 4, 2002 | 12:35 PM
mat89RS's Avatar
First you need to find out what year is the engine, for example 93 will not work that well because it wasn't a t-56. Also, you can buy straigh for GM a setup for Hot Rodders that will let you had any tranmission to the Lt1.
WejaZ28
Oct 3, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
